Fuse box/panel removal
Hey all, am new to site have been doing alot of research on here but can't find the answer to my question I hve a 1998 Tracker Pro Team 17 5 and need to remove the under dash fuse panel to get to a wire that is pulled loose was able to get trim off panel but can't figure out how to to get the fuse box itself loosened am hoping it is something simple that I am overlooking any help appreciated
Stealthbobber06
Don S
Re: Fuse box/panel removal
Boats in general have the fuse panel screwed on. But I have seen a couple that were glued on.
Look around for screws, the screws may be under the fuses if they are the glass tube type fuse.
Before you go prying on it and breaking things, you might want to post a picture of it. Then we will at least have some idea of what kind you have.
ONERCBOATER
i have also seen the darn things pop riveted on....definitely worth applying bright light and a mirror if needed to get a very good view prior to pulling on it.
Sean
Thanks for the reply Don there are two bolts that run thru the panel from behind the panel, but the nuts are recessed into panel, they are flush with panel so I can't get a wrench or socket on them it is raining out or i would post a pic
:facepalm: Ok, wanted to let you know I found the problem I had with removing the fuse box.......:rolleyes: the terminal ends attached to the box had caught on the side of the whole the the box sits in i had to bend terminals away from whole edge and she came right on out :D
Stealthbobber06
