Fuse box
mwhitten
Guy's
I have installed a fuse box for convenance, keeping all fuses in one place. I have used marine grade wire (tined) to power the box along with shrink wraping all connections. I'm in the process of redirecting the power and ground leads from instruments / radio to the fuse box. In some cases the wire gauge from the unit is small. Is it ok to attach a larger gauge (one or two sizes) wire to the existing wire? In most cases it would only be 24 inches.
Michael
bruceb58
Re: Fuse box
Guy's
Michael
As long as you keep the fuse sizes the same you will be fine.
