fuse location inside of Minn Kota Endura 50 ???
richg99
A friend has a dead Endura. Everyone is telling him to check the fuse ( not the circuit breaker). Is there one inside of an Endura?? Since I also own a
similar TM I want to know also. thx Rich
p.s. I did a serach and couldn't find a similar post. RG
fucawi
Banned
Re: fuse location inside of Minn Kota Endura 50 ???
As far as I know there is no fuse ..best test is to take the controller top off and find the thick red and black wires going down to the motor and apply 12v direct to them .. If it runs you have a controller mallfunction ..if it does not then its a motor problem at the bottom of the shaft. Remember never run out of water it burns the shaft seal ...Put some of this on the seal to keep it soft tight and lubricated
