fuse problem 89' evinrude 40 HP
shmeckle
the 30 amp fuse located by the terminal block on the motor keeps blowing. I have tried isolating the short. It doesn't seem to be from the switch to the motor. I had the solenoid tested it is fine. The motor runs fine when you jump the solenoid but ofcourse the guages wont work. Is it possible it can be from the switch to the guages? If so what is a good procedure for finding a short when there is a switch ?<br /> :confused:
