bds85466
- Joined
- Jun 11, 2007
- 375
Greetings,
I'm planning on wiring in some LED rope lights (12V) into the gunwales of my boat. Since I don't have any remaining switches/fuses open, I'm going to wire my own in.
I'm planning on using a max of 18ft of lighting, and the rating is max 0.8W per foot of lights. So the max would be 14.4W ... ~ 15W.
Dusting the cobwebs out from my circuits class, assuming a fixed voltage of 14V, the lights switched on would would draw: 15W/14V = 1.1Amps.
I'm guessing there's not a lot of current surge when you flip on LED's, but I'm trying to figure out which size fuse to utilize. I've heard in general, add 50% or so... 2Amp?, 3Amp?
I suppose that once I get everything set up, the acutal may deviate from the theoretical as well. I plan on metering my battery voltage (12 - 14?) and then also metering the amp draw of the lights on this voltage. All of the above theoretical numbers would be worst case as that's the max wattage, max footage and max voltage.
I'm just trying to figure out what fuse would be sized correctly so you don't keep breaking them and still be safe. Anything I'm wrong on or forgetting? Thanks for any help!
