unhip_crayon
- Joined
- Jul 3, 2007
- 53
Could someone please explain the purpose of a fuse box and how it works. What sort of components should be connected to the fuse box?
Thanks
Thanks
Do you own a house? The fuse box or circuit breaker panel on a boat performs the very same functions as the fuse box in a house. It is the central electrical panel for the boat. Simply put, +12 volts and ground wires run from the battery to the fuse box or circuit breaker panel. Every 12 volt electrical device on your boat such as lights, fish finder, stereo, VHF radio, bilge pumps, live well pumps, etc are all fed from this panel. Normally one fuse protects one device but sometimes more than one device is fed by a single fuse (instruments and their lights for example). If you didn't have a fuse panel, every device would need a separate in-line fuse and all the wires for those devices would all have to run from the center/front of the boat all the way to the back where the battery normally lives. You eliminate a lot of wire with a fuse panel and having all the fuses in one spot is more convenient than trying to track down a large number of in-line fuses and the entire electrical system becomes safer and more reliable.
