Inherited 1990s Starcraft with 60HP Mariner that has been dry docked for several years. Installed new battery and fresh gas and she fired right up. However, all of the instruments did not work. I located an in-line fuse back near the battery that was blown (corroded). Put in new fuse and got power to parts of the panel (radio, horn, depth finder) but still no tach or fuel gauge. Are there other fuses that I need to check/replace? If so, where are they? I've looked inside the console behind the instrument panel and nothing is obvious. Thanks. Joe
