Re: fuses
My '95 is the same. It is under the dash on the driver side. It is tucked in tight too. The only way to see and access it is to lay on my back on the floor and use a flash light unless you want more ease to work on it, take the lower panel off or loosen the top two brackets to allow the panel to drop down
