Fuses
dbergl
Trying to locate the fuse box for a Slyvan Expedition 1800 sport, my navigation light on the bow does not work. thank you
mr 88
Should be on the other side of the "dashboard " if not trace the wire from the switch. Did you run a continuity test on the bulb itself or clean the contact points on light assembly ?
gm280
Does everything else work? If so maybe you actually do have a blown light bulb for that light. OR the switch could be bad... So many things you just have to start checking and tracing wires...
