FWC 350 manifold question
offbase
Was wondering why it is necessary to run the coolant hoses through the manifold on a FWC engine? Any thoughts?
Re: FWC 350 manifold question
Ayuh,.... Welcome Aboard,...
Whether included in the freshwater side, or cooled by the raw water side,...
The manifolds are still Water Cooled....
which hoses ya talkin' about, 'n is yer system a full system or not,..??
offbase
Hi and thanks for the welcome. I have Marine Power 350 blocks that are closed system with heat exchanger and raw water cooled. I guess my question is why does the closed system run into and out of the manifolds? Car motors do not use the coolant to run through manifolds.
Ayuh,... Car manifolds have millions of cfms of air flowing through the motor box...
Boat motors run in a somewhat sealed box...
in close quarters to extremely flammable stuff...
offbase
So, the closed system goes through the manifold and cools the manifold down?
John_S
If your kit says to install one, best to do so. I recently looked at mercruisers closed cooling and saw that they run a hose from water circ pump to intake manifold. In the context of why I was looking at, it was for another discussion on coolant flow prior to thermostat opening.
See: http://forums.iboats.com/showthread.php?t=520775 post #12. Not sure it is the info you want or if that is the actual reason it is installed.
Lou C
The manifolds get hot enough, that you need the antifreeze that flows through them, to flow to the heat exchanger, to release the heat it picks up flowing through the manifold. The heat of the exhaust flowing out the exhaust ports heats up that cast iron pretty fast. Yes car manifolds are not water cooled but a boat application is totally different, closed engine box with no to little air flow around it...
