FWC number 2...
mattttt25
From what I read, there are two varieties out there- one cools just the block and one cools both the block and manifolds. So my question... if someone explained to you that "the block and risers were cooled, but not the elbows", which system do they have?
tommays
Re: FWC number 2...
The block ONLY would be a 1/2 system
The block and manifolds would be a FULL system
In some of my recent reading one rare issue with the full system is condensation forming because of the temp difference between the manifold and cooler riser and driping back into the motor ?
Tommays
mattttt25
Re: FWC number 2...
thanks, but he didn't state full or half. based on my description, what would your guess be. are elbows ever cooled?
tommays
Re: FWC number 2...
You sound full like a full system
Elbows (or risers) allways get water as it helps to calm down the flames on the way out :D
Tommays
HT32BSX115
Re: FWC number 2...
To my knowledge. There are NO systems where the elbows are "fresh" water cooled.
I guess you could (fresh-water) cool the elbows but you would need a water injector right where the exhaust exits the elbow. You would have to have raw water mixing with and cooling the exhaust gasses so you don't melt the rubber parts in the exhaust system and /or your stern drive.
ALL of them have "raw' water running thru the elbows.
The 1/2 systems do the block only to be sure but The full systems use block off gaskets between the manifolds/extensions and the elbow/risers to prevent coolant from getting into the elbows.
Some of the newer stuff has no path for water to get from the manifold sealing surface to the elbow so a tube is provided for raw water cooled systems to get raw water up to the elbow..
FULL systems require a somewhat larger heat exchanger to cool the manifolds.
Cheers,
Rick
Don S
Re: FWC number 2...
The elbows can not be part of the closed cooling. The water that circulates thru the heat exchanger must exit someplace and that is thru the elbow (aka riser) and out thru the drive. That water is needed to keep from burning the exhust hoses, bellows and on Merc Alpha drive the raw water pump.
That is why the full system is manifolds and engine and the half system is only the engine.
