Donald0039
- Joined
- Jun 11, 2022
- 418
This is a new to me boat. When I bought the boat the FWC was low on coolant and it took a few tries to get the cooling system filled with coolant and get the air out of the cooling system. Then while running the engine as a final test before an actual run in the water and a hose blew off where I had forgotten to tighten the clamp. So again needed to fill the system with coolant and get the air out of the system. Then I brought the engine up to operating temp again and after it cooled down I added a little more coolant.
This past weekend we went out cruising on the Delaware Bay for maybe 90 min. Came back in without any issues.
A day later with the engine cool, the coolant reservoir was down maybe 1 cup.
Trying to determine if I am loosing coolant somehow or still getting air out of the cooling system?
I ran a cooling system pressure test last year and no issues.
Coolant is pure looking in reservoir so most likely no mixing with the raw water in heat exchanger.
No coolant in the bilge.
Oil looks fine. Not milky.
