1992 evinrude 40 - Put timeing gun on plugs, top plug not fireing. Engine is running on one cylinder. I have a clymer manual but I am haveing a problem finding info on how to troubleshoot external coil. I was told that you couldnt troubleshoot the power pack. Same guy said the power pack for this model was located under the flywheel. Some work has been done on this moter. It looks like a power pack is mounted kinda underneath the external coil. Its a rectangualr box(black) w/ a ground and wires going to the stator, what else could it be? And if it isnt the external coil or the power pack what other possibilities are there. (Plug wires and plugs are good) Also what is the litte plug in the back of the motor w/ one wire comeing out, thermostat? Where is the rectifier?
