Iboats Boat and Motor Info
1. Year, make and model of boat
2009 G3 V 162C
2. Length, width and base weight of boat, look for boat decal on back of boat
16'5 7'6 1200 pounds
2a.What is the recommended HP for your boat
90hp
3. Number of people and gallons of gas normally on boat
2 adults, 16 gal
4. What do you use the boat for
fishing
5. Is it a Deep Vee and if so how many degrees of deadrise
Deep Vee
6. Year, make and model of motor
2008 Yamaha 90TLR
7. HP and gear ratio of motor IMPORTANT
90 HP, 2.0 Ratio
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape across the prop and the lower unit and then cut it between the prop and the housing and turn the motor until the tape lines up with each other, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
4500-5500
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches
Not sure
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
Trim tab
12. Make, model, diameter, pitch and whether SS or aluminum prop
Aluminum Prop, Make: Yamaha 13/58 X 13 K
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. If you do not have a tach you can buy a Tiny Tach for $ 50
WOT: 6100 37 spedo 2 adults
14. Are you at sea level or a higher elevation, give us the elevation in feet
Indiana
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the foregoing could be the reason your prop is not attaining full RPM Motor is new
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
Just bought the boat and it is the factory recommended prop
17. Does the prop show any damage that you can see
No...
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
I think the rpms and to high and want to bring them to factory recomd. But I also would like to add some speed. If I go to a 15 pitch would I bring down the rpms and lose speed or would I actually gain some because of the increase of pitch? Thank you, any help would be appreciated
2009 G3 V 162C
90hp
2 adults, 16 gal
fishing
Deep Vee
2008 Yamaha 90TLR
90 HP, 2.0 Ratio
4500-5500
Not sure
Trim tab
Indiana
No...
