Re: Gale 40 hp
If it's giving you trouble, give the puller's bolt a tap with a hammer. Not a whallop though! Then torque it up again, tap and repeat until it pops off. Failing that, try heating it with a torch and applying penetrating oil. Again, this is with a puller that works on the three 1/4" bolt holes. (I'm just trying to make sure you do the right thing here - I've seen a few of these where the flywheel nut got removed with a chisel, and the flywheel was popped off using a sledge!)<br />If it's really, really stuck, do not remove the flywheel nut but just loosen it. Sometimes when they come off they jump right off the crankshaft, and sometimes they do that when you're not around.<br /><br />Good luck!
