Gale Sovereign 60
Cheese51
I put new points and condenser in and only get spark out of 2 cylinders Its a Gale Sovereign 60 Model #60de13bl
Serial #861302 any answers?
boobie
Re: Gale Sovereign 60
Better make sure the other set of points are clean and set properly.
F_R
Agreed. One set of points fires two cylinders, #1 & #3. Other set fires the other two. Except for the possibility of two bad spark plug wires, everything else is common to all four cylinders.
Well another possible exception...If the spark is very weak on the two that are firing, it could be something else, like a bad coil.
