Game fisher 7.5 tecumseh
taylords1
I have a gamefisher 7.5 (tecumseh) thats flooding terribly. When the fuel is turned on it starts running out of the exhaust. What would be causing this and is it worth the repair?
sdb1966
Re: Game fisher 7.5 tecumseh
I got one of those little devils and I had the same problem ,a sticking float can do this allowing fuel to flood the carb and go down the exhuast port .I suggest you put a rebuild kit in the carb as the carb can get gummed up inside over time and there is also a rubber bladder in the carb that acts as a fuel pump and can cause flooding problems also. Ebay has a complete kit for $30.00 by Eskaman. I also would get a fuel shutoff and a mechanics manual from him also.The fitting is a 1/8 pipe by 1/4 barb valve. After rebuild my carb the motor starts on the second pull.
taylords1
Thanks for the responce and info. Pulled the carb float seems free and its impressively clean so probly the pump huh? Ill order a rebuild kit. Thanks
M
mrcrabs
Guest
Good luck, keep us posted.
