loose rivet
- Joined
- Jul 31, 2011
- 151
I picked up two super clean 1989 Sears Gamefisher 15hp motors at a flea market the other day.
Neither one runs, but both look like brand new and came with the original manuals and hang tags from when they were sold. There is no paint loss on the prop or skeg on either motor and the spark plugs look new.
Neither has any spark. Both feel like they have decent compression compared to my other motors but when I check them with my Snap On compression gauge designed for motor cycles, I get only 95 PSI on all cylinders.
I looked inside with a bore scope and the cylinder walls look perfect, they still have a nice crosshatch pattern showing and no sign of an upper ridge, the cylinder and piston top are spot clean as well. I shot some light oil in each hole before doing the compression test, if I shoot some heavier motor oil in each cylinder I get 100 psi.
Both appear to have dead coils, there is no spark at all. Before I spend any real money on these, does the compression readings I'm seeing sound normal? I see no signs of overheating, no signs of scoring, and from what I can see, there's no sign that either one ever had fuel in the carb, at least I can't smell any signs of gasoline anywhere.
I've got next to nothing in them right now, less than $50. The price certainly has me a bit suspicious as to why they were so cheap but the seller was selling antique camera gear and said they both belonged to an in-law who passed away a few years ago.
When I've tested other rope start motors I get closer to 125 psi or so, these are under 100. What should I be seeing? Does it sound like maybe they sat too long and have stuck rings or something? I've got a newer Chrysler 20hp that gives me 145 psi on the same gauge, I was expecting something closer to that reading.
