Gamefisher 15hp prop
Durango318
Hey everybody, I have a 93 gamefisher 15 model 225.581.506 made by force/mercury with what looks like a 8/6 I have a tiny tack rpm says it's running at 6,028 rpm this is on a 14 foot aluminum boat it will hit 23 mph gps verified, what is the correct rpm for this engine and what would the best prop iam looking for speed do I need a bigger prop?
steelespike
Re: Gamefisher 15hp prop
I believe the standard prop is 8 1/4" X 8 1/8" 15hp max rpm is 5750.
I think the above prop is closer to what you need.Hole shot will be slower but
top speed may be better.The 8 X 6 would push a load better.
Be sure the tach wire is carefilly applied and not picking up any stray pulses.
Durango318
The tiny tack was really a pain to setup, took over an hour to get a clear signal , kept getting a bad signal or nothing at all, I will try to post a pic of the prop tonight,
Durango318
Re: Gamefisher 15hp power
Sorry i cant upload pics of the prop, i think is a 8*6, i could be wrong though the 8 has a small cirlcle and a larger one if looking a the 8 big cirlcle of the 8 is on the bottom it looks like a 8*6 with it turned around it looks like a 9*8 with the big circle of the 8 on top sorry if this is confusing. allso stamped on the front of the hub is p713.
steelespike
To load pics you need to use a host site. Is it a through hub exhaust?
Depending on your total weight; your speed seems in the ball park.
Robbabob
I believe you have an 8X6. Purely by judgment of Steel pointing out what may have been standard (8 1/4" X 8 1/8" 15hp max rpm is 5750). You stated your max "6,028 rpm", making you nearly 300 rpm above where you want to be.
Going to an 8 X 8 will reduce your wot rpm appropriately, but it will also reduce hole-shot performance. Speed will likely go up.
Since you do not run a tach as standard equipment, I would deffinately go to the 8X8 pitch to help save your engine $$$$$$.
Good luck!
