I have a Sears Gamefisher 15HP Model 225.581507 The starter rope pulls normally and rewinds but it does not seem to engage and turnover.
There is a nut and rod (pinion?) attached above the flywheel which the starter fits over. There are roller bearings inside the starter assembly which seem to fit over the rod/pinion/flywheel. The pinion is smooth, no groves or teeth. How does the pull starter engage with the flywheel? Is something worn? What needs to be fixed/replaced? Please help.
