Gamefisher/Sears 217-585241 3.5
keyser
I acquired a 1979 Gamefisher 3.5 model 218-585241 this week. I was told it ran a year ago. Tank was empty, I cleaned the carb, and replaced the plug. I am not getting spark. Does anyone know a source for OEM points or compatible replacements? The condenser is marked 30548-B. Also, this model appears to be air cooled, although it has intake ports?
brim_buster
Ohm test the condenser and clean the points. But you can get both at Napa if you need them. It has a water pump on the 3.5hp to cool the exhaust gases and leg. That has a Tecumseh AV-520 power head I believe. Points set at .020.
keyser
I found the parts, when I search out this motor, it looks like there is no impeller? Any idea what type oil to fill the lower?
brim_buster
I just checked a chart I have and it says no impellor but the manual said all motors bigger than 3 do. I restored a 4hp and it had one. I use synthetic 80w in the foot. Walmart has it.
