gamefisher
flipper95567
I have a 1990's ( not sure on exact year) 9.9 gamefisher. Can anyone out there tell me how to disconnect the transmission link to change the impeller please?
roscoe
Re: gamefisher
Not knowing the year, I am guessing that you have a Force motor, with the Gamefisher nameplate on it.<br /><br />Put motor in forward.<br />Remove 4 bolts that secure the lower unit.<br />Drop the gearcase as far as you can.<br />This should expose the joint in the shift shaft.<br />There is a screw that secures the 2 halves together.<br /><br />You really should get a manual, as re-assembly and adjustment can get a little tricky.
