Garelick Eez-in jack plate question
chris16371
Friend of mine is giving me a nice small 14' aluminium and I'm going to transfer my 15hp Suzuki motor over to it. On my fiberglass I put a piece of 3/4" red oak play wood on the outside back before I installed the Garelick jack plate bc the transom is oddly shaped kinda like a triangle so I needed to in order to level it out. Should I do the same with the 14' aluminium? The transom is completely flat so I don't have the same problem as fiberglass, there's also wood the width and height of the boat in the back.
redneck joe
if it mates up flat, and you have enough thickness/strength already I see no need but overbuilding is usually not a bad route to take.
chris16371
That's kinda what I was thinking. Has a new transom as well so maybe I won't need it but I guess every little bit helps, just don't want to get to much weight on the back.
