Garmin 182C Battery Alarm
BULLWARKS
Every once and a while I get a "LOW BATTERY" alarm on my GPS. Don't know why the main is charged anr the F150 is putting out about 14v when it happens.<br /><br />ANY CLUES?
dingbat
Re: Garmin 182C Battery Alarm
It could be a bad or dirty connection and it may not be your boat battery at all. <br /><br />It could be thatyou need to change the CMOS battery internal to the unit. The CMOS battry needs changed from time to time.<br /><br /> Do you loose your presets from time to time? This is the first hint of problems with your CMOS battery
BULLWARKS
The GPS is new in May 2005.<br /><br />Havent lost any info or presets.<br /><br />Where is the CMOS Battery?
imported_Curmudgeon
Adjust one of your data boxes to show voltage, unit voltage should be within approx 0.2 volts of actual system voltage or else you have other issues; this alarm (when set to "on") is generated when voltage sensed by the unit falls below a preset alarm level.<br /><br />Go to the "Alarm" menu and see if it's "ON". If so, is it set to a reasonable voltage (the unit will actually operate down to 10 volts)? If it's not "on", better call Garmin.<br /><br />This alarm has nothing to do with CMOS ...
