faulkemup99
- Joined
- Jun 19, 2005
- 20
I posted in the Johnson Motors section originally but was told since the problem sounds electrical, to try this forum, so here goes:<br /><br />I have a brand new Garmin 188C Charplotter/Sounder combo unit. I had it professionally installed. Ever since getting the boat back, it has run horribly(steady miss) above 4,000 RPMs. Never ran like that prior to this, motor has been great(93 Johnson 140 V4 2-stroke). I decided to try running it without the GPS connected, motor runs GREAT. Plug it back in, turn it on, motor misses. Any thoughts? <br /><br />1. The GPS power and neg are connected to a fuse panel under my dash. The red is connected to the "MAIN" connection, where the hot from the battery is connected( I guess this is where the fuse panel gets its power. There was an empty fuse bank but the mechanic opted not to use it, instead, connecting it to "Main"). The unit does have an in-line fuse. The neg is connected to the fuse panel as well, at a 4-bank connection plate.<br /><br />2. The transducer is hooked up as well, they ran the wire back through the hull with all the other wires.<br /><br />Which one is more likely to be the problem? My feeling is its the transducer line. If that is the case, whats the best way to isolate that line, as I dont know where else to run the wire to the back of the boat?<br /><br />Any help is greatly appreciated.<br /><br />Would love to be able to use the motor AND the GPS/Sounder at the SAME time, lol!
