Garmin- Chart Plotting Speed
Bassn7
How fast can I go and still get a good map of the lake when recording? I have never used it yet.
Marty
depends on so many factors:
What Garmin you have
what transducer you have
what type of water youre boating in
what type of hull you have it bolted to
is there debris in the water
did a fish fart in front of the transducer
call Garmin to get a rough ballpark idea
go out and try it to get a real idea
dingbat
25mph and under is what is recommend. After the boat speed goes over 25mph the green circle will turn yellow to indicate that it has passed the optimum performance.
As long as you have bottom lock it will continue to record. Calmer conditions will provide better results.
Bassn7
Great. Easy. I was concerned under 3 mph. I want to record at 7 mph. Should be fine then. Thanks all.
