Garmin Echomap - In Parallel?
Bassn7
Can I run 2 depth finders to one transducer? I want a screen in the front of the boat but use the rear transducer.
dingbat
You can swap a transducer between units but you can't connect both at one time. But.... you can share displays (same screen both units) between two ECHOMAP units via NMEA 2000.
Bassn7
So I can...I want the same display on both units at the same time. Correct?
