Garmin GPS MAP 180
azizianuar
Hi:<br /><br />I have a Garmin GPS MAP 180 which is showing a message of Low Memory Battery. I've contacted Garmin, and they say is $150.00 to work on it, plus according to them no one else can replace the battery. Has anyone had this experience before? Could I just open the dam thing and replace the battery myself? Or do I really have to DO AS THEY SAY...<br /><br />Thanks!
JB
Re: Garmin GPS MAP 180
Getting them to replace your DRAM battery is a lot cheaper than a new unit, Azizi.<br /><br />It is not just a matter of pulling a few screws to get it apart, or putting them back after the new battery is in place. You will probably end up with a whole new waterproof case.<br /><br />If the 180 suits your needs, a new battery is the way to go.<br /><br />Good luck. :)
