BiXLL
- Joined
- Aug 4, 2003
- 266
I have a 29 gal gas caddy with the hand pump. I kind of fell into it when buying my boat and only have $75.00 tied up in it as it originally didn't have the pump. This is my first year of actual boating, preceded by 10 years of jet skis. I had always fueled my 7 gal cans in the back of my truck without even thinking about static electricity with no problems. (probably lucky?) I have read bits and pieces about static electricity dangers, and plastic fuel cans from different forums I frequent. What are the facts? Can I fuel the caddy while still in the back of the truck (with bed liner). If static electricity if a problem, can I attach a ground wire from say the metal pump on the caddy, to the steel part of bed? What is my safe solution here?<br /><br />Also, I can not fuel at my slip. I must move boat into open water away from slip. Do I encounter the same static electricity problem with the caddy on the boat? I have a Catamaran Cruiser, which is basically a fiberglass pontoon boat. Wheeling the caddy on, and stowing it is not a problem, but would it need some sort of grounding on the boat? If so, to what?<br /><br />I really want to use the caddy, as the single source of on water gas is almost twice the price of gas at any of the local stations. I don't want to do this carelessly though, and have found I am not knowledgeable on this subject at all. Any and all suggestions, and guidance here would be very appreciated!
