Gas cap replacement
RockChalk01
The dock boy dropped my gas cap into the water the other day. So I need to replace it but I having problems locating the part # I need? or if by chance anyone knows the size I would need to buy a replacement in? Thanks in advance for any advice
It is for a 2014 Premier Sunsation 220.
Davetowz
A picture of tank would help. Is there a manufacturer name on the tank?
Unless you know what brand of fuel fill you have, you will need to replace the fuel fill and cap.
They are not universal
I would have thrown the dock boy in the water
RockChalk01
Trust me I was tempted to throw him in after it :)
Here a pic I took last weekend since the one I bought was way to small.Fuel cap.jpg
Since there are no standards for fuel fill. You have to find the exact one. Or just buy a different one
flashback
Most all I have seen have a tether on them so don't be too hard on dockboy..
ahicks
If you get tired of beating the bush looking for a replacement cap, there's also the possibility you could replace that entire fitting for one that comes with a tether on the cap.....
tf2692
I am thinking I need a 1 7/8 inch one?
Looks like a built in tank and NOT a portable one, do you know if it was a vented cap ? , you can check with your local dealer, they should be able to help if you give them the make and model of the boat, and yeah any dedicated dock boy would have dove in after it😂, hope this helps cause I know you don’t want to cruise around with a rag stuck in there🙂
