Gas dripping out of pisser
Platypus E65
What would cause gas to drip out of the pisser of my 2007 E65WDRLSCS? Every time I stop the motor it would drip for about 20-30 minutes then stop. I opened the cover but didn't see or smell any gas fumes when I brought it home one day. Any ideas? Thanks.
SparkieBoat
the only way I can image that gas would drip from there is if you have a leak under the cowl and it is pooling up in the bottom of the engine compartment. better get that fixed or possible big BOOM
Platypus E65
Thanks for your feedback, SparkleBoat. Looking around online I found someone else that had the same problem and his solution was to swap out the VST.
WernerF
The tell tale water (cooler than the cylinder head) is fed through the EMM and the vapor separator before it finally exits the engine. I think, the vapor separator is leaking fuel into tell tale.
