gas fumes in ranger 392v
moffett cr.
Have battery compartment open and can smell some fumes.I check line and hatch with flash light but can not see anything wrong or damp.Can the tanks be venting off some?
izoomie
Re: gas fumes in ranger 392v
If it is, the vent should be outside the closed compartments. Gas fumes are nothing to fool with, I would get a mechanic in there before you do anything else.
Chris1956
That is a dangerous situation. There should be no fumes in the bilge. Look for leaks at the fill, vent and fuel line that leads to the engine. Sometimes the tanks themselves can leak. Is your tank aluminum or plastic?
moffett cr.
Not sure what tanks were made of in that year and can't see in there. The hatch has been open for over a week as I have been working on new fish finder,maybe fumes from vent are being sucked down? I will close for a while then check before I take it to the shop.
Chris1956
There should not be any fumes in the boat that could go into the battery compartment. You have a leak, IMHO.
greenbush future
How old is your boat? tanks can wear out, rub or vibrate loose, gas lines and hoses can wear or rot from ethanol too. Excessive fumes is nothing to take lightly, I would be disconnecting your battery ASAP until you fix the issue.
moffett cr.
Thanks all,I have been sleepless over this so I ran it up to the boat repair today. I well be back as soon as I no more.Thanks Again
Illinoid
I would also be very careful about disconnecting a battery in this situation...
