Jennifer "water-wolf"
- Joined
- Aug 8, 2011
- 41
It's not exacly engine and outdrive but it IS related
...1994 model, V6 with Alpha One. I have the original factory install manual that Mercruiser gave the OEM boat manufacturer, and the electric harness and gauges are exactly what is described in the Mercruiser install manual. I suspect that my boat builder [ Blue Water Boats, then in Springfield Oregon] just got complete power/out-drive/electric packages from Mercury, but that is just an assumption on my part....
After spending the winter in a heated warehouse we took 'er out a few days ago on the first outing of the season,:joyous: and found the gas gauge not reading.:grumpy: We motored from the marina to a gas dock and added over half a tank worth of gas just to make sure we had some...and still no movement of the gauge. Anyone got any ideas where I should look first? It was functioning fine when last out in October, with about 1/4 tank remaining on last use. The boat has been quietly waiting in a heated warehouse, not subject to rain or freezing temps....If there is typical failure mode, is what I am looking for advice on....next week I can put 'er out on a work platform and trace everthing out with a volt/ohm meter, but if there is some advise as to what to check first, it might save me some time or frustration. Also of interest would the typical ohmage that I should read from the sending wire to ground through the sending unit, at empty and at full..... . I have had trouble with the trim gauge not working too....and that was traced once to a faulty install of the sending unit on the out-drive, after a service we had done, and the second time to a bad splice someone had made in the sending unit wire under the dash....and it is out again too, but I am quite familiar with how to trace that circut now. I have very long extension test leads for my multimeter, so I can connect right at the sending unit and go all the way up to under the dash if I need to. Thanks for any help in advance. Sure hope I don't have to spend big bucks on a new sending unit, which is also hard to get to for removal and replacement. I can reach it easily to clip on test leads, but to replace it, I would probably have to remove the entire rear seat bulkhead.
Jennifer
Jennifer
