Re: gas gauge
NEVER implicitly trust a boat's gas gauge. I have VERY rarely seen a marine fuel gauge that was dead on all the time. Matter of fact, I don't think I've ever seen one. I take that back. The ONLY fuel gauge I will trust is a yard stick stuck in the fuel filler with the boat at a dead stop. Of course, this is likely impossible on most boats, as the fuel filler to tank is rarely a straight shot. The fiberglass tanks with the clear sightline on the side are usually pretty good, too. Other than those, use the gas gauge as a reference only. If it's bobbing around, then you've got some fuel in the tank. If it normally bobs around and suddenly it DOESN'T - then you're on the low end. <br /><br />You can figure out a ballpark idea of your tank's volume by doing some measurements - length/width/depth etc. and then converting to gallons. One cubic foot holds about 7.5 gallons. A fuel meter can tell you exactly how much you've used and go from there...<br />- Scott
