Re: Gas in Carberators
Nope. Never had any problems with mine being laid up for 5 or 6 months. As long as you run it for 10 or 15 minutes to get the stabilizer into the carbs, it will be fine. People underestimate todays fuels. They are good for longer than you might think. I never used to use anything up until about 5 years ago and still had no problems in the spring. Add stabil and I would not be afraid to leave it for up to a year. As a matter of fact, I did not fire up my boat since last August(2003), until a couple of weeks ago. That's about 9 months! No problem at all...<br /><br />On a side note, I did pump up the primer bulb every month or so, to replenish the fuel in the carb bowls, as it does evaporate over time. Plus, it gets a shot of fresher fuel in the bowls that way.
