The diaphragm in the pump cracks letting raw fuel into the crank case via the pump lever hole.
No.Yes it has this hose,but didnt c no gas in the hose. If the fuel pump is letting gas in oil,Could this b the reason my motor startd running rough???
The tube from the fuel pump to the carburetor flange will cause the engine to run rough if the diaphragm goes bad, thats it's purpose, in turn the overly rich running condition will contaminate the crankcase oil with fuel.Yes it has this hose,but didnt c no gas in the hose. If the fuel pump is letting gas in oil,Could this b the reason my motor startd running rough???
Yes!!! Your fuel pressure is most likely very low because the gas is going into the crankcase instead of the carb's float bowl.Yes it has this hose,but didnt c no gas in the hose. If the fuel pump is letting gas in oil,Could this b the reason my motor startd running rough???
