Thompson66
- Joined
- Jan 28, 2005
- 10
I have a 1966 Buick OMC v6 225 cubic inches engine. I believe that I have gas in my oil. My engine idles fine but it was coughing under load. Among other things, I checked the oil and it was thin with a gas smell. I do not believe that it is water because it is not milky and there is no separation of water from oil. I conducted a side by side comparison test. I drained the oil and got about 5 qts. My engine holds 4 qts of oil. This means that I have an extra qt of something. I pulled my carb and it was clean. All passages were open. I unbolted my fuel pump and checked it with a vacuum gauge. The upper and lower chambers held vacuum without leaking. Where else do I need to check? I am inclined to believe that its a bad fuel pump, given that it was running lean under load. But why is there no vaccum lost? If it is in the Carb and loosing that much gas, why would it idle without flooding out? What do you fellas think?
