texasvet54
- Joined
- Nov 5, 2010
- 267
I have a 250 HP Mercruiser with under 300 hours on it and I just drained and replaced my engine oil. Instead of the 5 qts. that I installed last year, i have 7 or 8 quarts of something that is obviously not entirely oil. This happened last year when I replaced the oil for the first time. I took last years old oil to the local Mercury shop and I was told that it was definitely not water in the oil.
The old oil is light black in color and has a hint of a smell of gasoline in it. Last year I let it set for a few weeks after removal and I noticed no separation whatsoever. I might add that I only have 12 hours of engine run time between now and last year's oil change as the engine is on my houseboat that mostly sits in the slip.
I have a raw water system and I have noticed that my engine never gets very hot while running. I have worked on cars for many years and I was wondering if maybe I have a cylinder that is not firing and the gas is flowing past the rings and dripping into my crankcase?
Any thoughts?
Any thoughts?
