Noticed tihs weekend that I have gas in the water around the motor whenever I shut it off. Not a huge amount; but enough that I can see & smell it. Slick is broken up, not a big solid slick & extends maybe 3' around the motor (if that gives you an idea of how much gas is coming out). No gas smell while running the motor & it seems to be starting & running smooth. Motor is a 1999. Is there a float or something that might need to be adjusted to keep the bowls from overflowing? Maybe a valve that's should be closing that sticking? I have the factory manual (not a repair manual), but didn't see anything in there.
