Today on the water my engine just shut down and would not run wot. I checked the primer bulb and it was flat. After I got home I found that the sending unit was leaking gas and when I tried to tighten the screws I found that three were stripped. I went and got some larger screws (5/16) and the heads on them were to big to tighten down around the base of the sending unit.
Has anyone had to troubleshoot this problem before? How did you fix this?
I'm thinking about pumping all gas out of the tank and filling the screw holes up with marine tex. Then I will re-tap with the correct size screws and a new gaskit. Any thoughts or comments are much welcome.
