Gas Leak, Gas Everywhere In Bilge!!!
stug
haha got ur atention..
but yes I do have a small gas leak I have noticed. I have a Mercruiser 3.0 130 hp in a 1987 glastron with a alpha 1 outdrive. I had to do Head work a few weeks ago after roasting a head gasket. During that process i had to loosen and swivel the gas line. Loosened at the fuel pump top connection to turn line, to access top of block better. The compression fitting to the carb resealed no problem. But after running a few hours, I ve noticed a slight drip from the rubber sealed connection at the fuel pump top nut.
Is this a standard old school automotive fuel line rubber fitting? 5/8 line I believe.
I dont feel like having an explosion while tooling down the river.
:eek:
Don S
Re: Gas Leak, Gas Everywhere In Bilge!!!
Nope, it USCG approved Type IA fuel hose for boats. It's also 3/8" hose. Measured from the ID.
Click here for hose and fittings.
stug
ty, my good man.
always go to best, It saves alot of time and headaches.
:D
stug
hey Don after searching thru those parts, I havent found what I need
ok everybody
here are some visuals
feel free to jump in
ok it leaks here
WoW
Don S
No, teflon tape never helps anything in a fuel line. BUt it will get bits of the s*** going thru the carb and plug everything up.
What you need is a new line. See your Merc dealer, you need part number 32-14797 1 and it costs around 40 bucks. the fittings inside crack.
Sorry about your ugly kid...........Geeeeezzzzz. You created that??? No wonder you tried teflon tape, but, you used it in the wrong place.
stug
lol, yeah we keep him locked up in the basement
He still manages to get out though.
but ty, for the part update
delsol
stug-don
funny stug.
180shabah
...Sorry about your ugly kid...........Geeeeezzzzz. You created that??? No wonder you tried teflon tape, but, you used it in the wrong place.
