1994 225hp Johnson. Cranks, idles and wot just fine. VRO has been disabled for a long time. Seems to always have gas/oil mixture running/staining down the outside of the midsection after sitting. I take the airbox off and the throats/front of carbs are dry, I check the carb bases good and they are dry. There is a hose between the bottom two carbs, coming from the crankcase, it is only plugged in at the crankcase and is about 4 inches or so long and just sort of points down into the airbox. I assume this is the hose that pulls the "blowby" back into the engine to be recycled. It looks like the drippage I am getting running down the midsection is coming from this hose......is that possible? Thoughts
