I have a 1990 Nissan 70 H.P. motor. I am planning on installing an in line gas filter to the gas line going from my under floor gas tank to the motor. The filter is made of clear glass with the filter on the inside. It is a throw away filter, in other words, it does not come apart to change the inside material, you just remove it and install a new one if needed.
The filter will be place in the gas line about 16" before the motor which is well above the primer ball. Is this a good idea or is this going to have any ill effects on my motor as long as I have the right sized fittings for the gas line and also as long as the filter is "clean" and not plugged up?? Thanks.
