JohnnySCV
- Joined
- Jun 24, 2008
- 71
Hello and thanks for reading.
I have a 1992 20ft Champion Bass Boat with a 200 HP Mercury outboard Carburated not EFI. I recently purchased the boat in late October and it seemed to suck up gas like no one's business. Since that time I have changed from a 23 pitch 3 blade prop to a 25 pitch 5 blade (both stainless). I had the voltage regulator replaced as it was not working, and the timing was slightly off at WOT so I had that adjusted. Since these changes have been accomplished it seems to be easier on gas to the point that it is very noticable. Could one or any of these adjustments make that much of a difference? My other thought is that the boat was not run very often and now that it is being used regulary it's running more efficiently (not sure if that is even possible)
Anyways, thanks for your thoughts....
