I tore down my 95 Johnson 90hp j90tleor to hone a scored cylinder and put rings on other pistons. Everything is back together. The compression in all are between 115&120, there is good spark. The fuel pump has a strong pulse of fuel to the carbs but it seems to stop there. The plugs are completely dry when cranking. The carbs are clean. Could the timing be so far off it wont even try to fire? Any suggestions? Thanks in advance! Oh and at idle does this engine only run on certain cylinders?
