Re: gas/oil mixture on 1958 sea horse 7 1/2
Been there done that <br /> The old SAE 30 mix left the boater with loose fillings and long arms. i.e. It did not mix well.<br /> SAE 30 ,if I remember correctly,is standard weight 30 viscosity automotive motor oil.<br /> Use any tc-w3 rated 2-stroke oil at the 24:1 ratio. <br /> With a bit of regular preventative maintenance that little clasic John should last more than a life time so add it to your will.
