bds85466
- Joined
- Jun 11, 2007
- 375
So I'm sure nobody -- well most people -- do not get out a graduated cylinder and measure their ratios as they're filling up the tank, so my question is this: How accurate is accurate enough when it comes to your premix?
Given a couple things:
Most of the time I fill my gas tank, using the gasoline gallon read-out, plan accordingly with the 2 stroke oil, using the conversion on the back of the bottle. Now there's only graduations at every so many ounces on the oil and it's completely guesswork as far as I'm concerned.
After many times of filling your tank like this, could this make a difference? Depending on how much oil you're over or underestimating? Does one or the other tend to "stick" (oil and gas that seperate?) in the gas tank?
How much deviation matters when it comes to actual engine performance? What happens (what sort of immediate symptoms arise) when deviation goes out of "tolerance" in either direction? If it came down to it (obviously it's best to get it right on), is it better to overestimate, or underestimate your ratio?
