gas pours out of carb! help!
Red9654
on my 1969 Chrysler 45 hp outboard model 4545, wen i go to start it gas pours out of the hole of the carb in pic number one. the boat wont even start now. it never did that until today. the hole there leads down into the fuel bowl for the carb. does anyone know how to fix this?? and gas comes out the front of the carb by the choke shutter, how do i fix that?? (pic 2) thanks for any help!carb 1.jpgcarb 2.jpg
gm280
Re: gas pours out of carb! help!
With only the info provided, it would seem that you have a stuck needle and seat situation in that carb. Maybe a great time to do a complete overhaul and replace the needle and seat AND the gaskets as well. When a needle won't close (for any reason) the carb will allow the full pressure of the fuel pump to pump gas at will and it has to go somewhere...
jerryjerry05
Your gonna have trouble with the "new " parts.
Most times they don't fit.
Clean the carb and post pics of the inside?
Don't use any "carb cleaners" they can affect the rubber in the seat.
I use Dawn soap and water. Then compressed air to dry.
No WD or any silicone sprays.They just gum it up.
If the parts on the inside are that bad?
Valley Sales in Prudenville,Mi. will probably have the parts.Call him, he doesn't answer e-mails very well.
The air screw start at 1 turn out and adjust from there.
