Ok well it was not gas it was oil. The oil cooler went replaced and changed oil five times as there was water in oil. That is all good but know as it seems I have another problem boat runs great for about 20-30 min then I start loosing power on starboard same side as oil issue. When I loose power I have to bring throttle down run slow at about 2000 rpms for a bit then I can push it up and runs good again we tested fuel pressure that's all good. Changed plugs caps rotor still happening I'm at a loss ??
