gas ratio question for really old outboard
hitace
what would be the ratio for a 1939 johnson is it 24:1 or will i have to do 16:1
JB
Re: gas ratio question for really old outboard
According to OMC in 1964, it should be 24:1, but the latest from BRP says 20:1.
If I had it I would do the 20:1 thing.
tmcalavy
Original spec was 16:1 but you can probably go 24:1 with modern TCW-3 marine oil. It needs at least that heavy a mix cause it probably has bushings and not bearings inside...oil is cheaper than NA parts if you want to keep it runnning.
